주요 콘텐츠로 건너뛰기
모델 A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
Reuse the camera and microphone (iMac, Mid 2011, EMC 2429)
I got this fully functioning iMac for $80. Apparently it's too slow for anything. So I'm trying to convert it into an external display. And I want to reuse as many parts as possible. While waiting for the LCD panel control board, I decided to take a crack at the camera and microphone.
I came across this post that has a pinout of the camera. I soldered 4 wires to a USB connector and it seems to work but there are two extra wires (SMB_ALS_SCL & SMC_ALS_SDA) that are not connected. I thought they were for the microphone, integrated in the camera assembly. However, then I found a tiny device with 2 wires that looks like a microphone:
A quick search also verified that it is indeed the analog microphone (weird that Apple used an analog microphone).
Now, I guess I need to convert this analog microphone into a USB one. I am not well versed in analog electronics although I know what needs to be done (amplifying, ADC, sampling, sending PDM data to host). Does anyone have an existing solution that I can copy?
Also, the question now remains, what are the two unused wires (SMB_ALS_SCL & SMC_ALS_SDA) from the camera for?
Thanks.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
ALS = Ambient Light Sensor
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Duh! Thanks! That totally makes sense. I guess I can completely ignore it then.
댓글 달기
답변을 추가하세요
Deling Ren 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 18
전체 시간: 252
