주요 콘텐츠로 건너뛰기
모델 A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
iMac 2011: Fans at Max Speed, CPU Throttled to 1.7 GHz
Hello everyone!
I'm experiencing a serious issue with my 2011 27" iMac and can't seem to find a solution. Here are the main problems:
- All fans are running at maximum speed.
- The CPU is throttled down to 1.7 GHz.
- The GPU is operating at only 20% of its capacity.
- After waking up from sleep mode, everything works normally for about 10 seconds, but then the problems return.
Here's what I've already tried:
- Replaced the CPU with an i7.
- Replaced the logic board.
- Installed new RAM.
- Upgraded the SSD (from a Samsung 840 EVO 500GB to a Samsung 870 EVO 1TB).
- Installed an OWC In-line Digital Thermal Sensor specifically for my model, but it didn't resolve the issue.
- Disconnected the central HDD fan because it was very loud; however, reconnecting it didn't change anything.
- Reinstalled macOS High Sierra.
- Reset NVRAM/PRAM and SMC multiple times.
- Checked all cables and connections; the LCD Proximity sensor appears to be in perfect condition, but temperatures for Hard Drive Proximity and LCD Proximity are not displayed.
I'm using Macs Fan Control, Intel Power Gadget, and iStat for monitoring temperatures, but nothing changes: the CPU remains at 1.7 GHz even under load, and the GPU runs at minimal capacity.
Has anyone encountered a similar issue or have any suggestions on what else I can try? I would really appreciate any advice or help! Thank you!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 5개
@gidrogen just to clarify. Nothing changed after you replaced all of those parts? The symptoms are identical with the old parts and all those new parts?
@nick hey Nick, you tend to be pretty good with Macs, do you have any ideas?
@oldturkey03 Unfortunately, nothing has changed after replacing all the components I mentioned.
Have you tried changing the fan speed manually in Macs Fan Control? That's how I got around the full blast on my 21", and I've had no problems.
@bestofthew52619 As I mentioned, I am using Macs Fan Control, but it only partially resolved the issue with the fans. The CPU and GPU continue to run at low speeds.
댓글 달기
답변 2개
선택된 해법
I’ve often encountered damaged inductors around the fan cable connection near the heat sink
Update (10/02/24)
I'll need to dig into my stuff to find a better image and there values, here's the location of the inductors
They are very small! You'll need a good magnifier to inspect them.
As to why the problem is present on both boards, could you have damaged them on both?
이 답변이 도움이 되었나요?
점수 0
댓글 27개:
Have you encountered issues related to reduced CPU and GPU frequencies? I mean, have you observed a decrease in their performance?
@gidrogen - Yes! Diagnostics won’t show the issue. These are small SMD devices that if your not careful get damaged trying to disconnect the cable.
@danj So, are you suggesting that the issue might be with the fan cable? Am I mistaken? If that's the case, how does it relate to the low CPU and GPU frequencies?
@gidrogen - Not the fan cable those little things near the connector if I remember correctly marked L101 & L102. What happens is the pressure of the tool resting on them breaks them when you try to disconnect the cable.
I have disassembled my iMac but was unable to locate the L101 and L102 modules. I thoroughly inspected the motherboard, and it appears to be in perfect condition. Additionally, I tested a second motherboard that I suspected might be the issue. However, replacing the motherboard with a new one did not change anything, and both boards look flawless.
댓글 22개 더보기
댓글 달기
The only thing I can reasonably assume is going on here is that the software itself is trying to underclock your CPU somehow, almost like they do with iPhones and intentionally degrading performance to keep the battery life somewhat consistent.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I have reinstalled the system, replaced the motherboard and SSD, and set everything up from scratch, but the problem still persists. Therefore, no program that slows down the computer should be present since I set everything up from scratch, but I can't resolve the issue :(
댓글 달기
답변을 추가하세요
GidroGen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 449
