주요 콘텐츠로 건너뛰기
Apple의 M2 SoC가 탑재된 2022년형 13인치 MacBook Air에 대한 수리 안내서, 지원 및 문제 해결 정보입니다. 2022년 7월 15일에 출시되었으며 모델 번호 A2681로 식별됩니다.
Keyboard and touch id replacement
Hi, I would like to change the top case of the MacBook Air 2022 for some problems on the keyboard and that one has the Touch ID button connected to the T2 chip. But should I do as it was done before with iPhones?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hello, Yes, the Touch ID is serialized with the Motherboard. Which means that if you are going to replace the keyboard, then you are going to need to keep the Touch ID Sensor.
Best of Luck to you!
이 답변이 도움이 되었나요?
점수 0
댓글 12개:
thanks. also i need to migrate the small logic board under the motherboard? what a rage, to fix the small hook of the space bar I have to replace the whole upper case with the keyboard ....
@davidemaglio - Check your warranty coverage! some countries offer two years. You might get it covered!
@danj Now that you mention it, doesn't apple double their warranty if you buy with a specific credit card? They might get 4 years of coverage depending on how they bought it.
@jmehnert and @danj, I know but I'm about to buy a used MacBook Air. the only hope I have is that the warranty on the serial has not expired and try to have it repaired, but I see it difficult to prove that it broke accidentally... (although I would like it so I could put the US or UK International keyboard, I prefer it to the IT one)
@jmehnert - The extended card coverage is via the card company, not Apple directly (they handle the repair).
댓글 7개 더보기
댓글 달기
답변을 추가하세요
Davide Maglio 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 42
전체 시간: 340
