주요 콘텐츠로 건너뛰기
MacBook, MacBook Pro 및 MacBook Air에 사용되는 AC 전원 어댑터. 잡아당길 때 안전하게 분리되는 자가-정렬 자성 커넥터를 사용합니다. 1 세대 (2006-2012) MagSafe 충전기는 약간 두꺼운 L 자형 커넥터가 있습니다. 45 W, 60 W 및 85 W 버전으로 제공됩니다.
65 질문 전체 보기
질문 마감됨
How to fix a cable that's been cut in half?
So my Magsafe conector got sliced in half around 3 inches from the end that connects to the computer. I've watched videos of the head being fixed but is there any way to solder the cable halfway?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
선택된 답변
Here is a video that may solve your problem. Arrow down to the bottom for the video. Good luck.
http://www.philmug.ph/forum/showthread.p...
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
I don't see why not. Just make sure you insulate the wires from each other, you can use electrical tubing or electrical tape.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Nothing works
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Sajs, nothing works where? what is not working? If you are looking to find an answer for something that is not working, you should give a bit more of a response. Like what it is that is broken,what it does, or does itnot do, what you have tried to fix it, etc.
댓글 달기
Yes it can. I replaced the cabling on my charger by cutting the cord close to the damage (from my cats) and adding the new cord from there - rather than opening up the charger.
The cord has a shielded inner set of wires which is positive (?) with the negative (?) running around the outside. Separate the two, solder them up to the other end of the cable, insulate with electrical tape and you're done.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 4
전체 시간: 6,917
