What are the 3 golden notches inside the watch?
What are the 3 golden notches inside the watch? 2 on the screen side. One from mine got removed, now my sensors are not working. I do not know if that is the reason though. As in my wrist does not get detected, thus the watch automatically locks itself.
Update (10/24/24)
thank you so much for replying instantly, i did not expect that.
https://imgur.com/a/TsCSPdC here is the link to what got removed. I already tried putting it back glueing with B7000 the black underside part of the gold notch.
For context, my watch got damaged by water - stuck in bootloop for weeks. A repair shop said it is a faulty board and they'll try fixing it in exchange for a big amount of money.
I then submerged the watch in 99% alcohol like 5 times until it turned on again. Everything is working fine perfect. and used it for 2 weeks.
However, I'm trying to remove the old adhesive to prepare reapplying adhesive, then the gold notch got removed. After that, the sensors do not work and my wrist is not detected
좋은 질문입니까?
댓글 1개
If you are talking about the SIP module the larger ones in the corners are manufacturing fixture point to hold the SIP during it’s construction and is also a chassis ground point. You really need to post a prober question with a clear picture of the damaged part.
DanJ 의
