주요 콘텐츠로 건너뛰기
A standard cordless compact DeWalt 18V drill with a high performance motor that delivers 380 watts. Equipped with easy to hold design that allows you to work in difficult spaces.
What's the biggest 20V pack that can be SAFELY run?
I have a DeWalt DC970 from years ago and no batteries as they are dead. That said, I have primarily moved to 20V tools but this drill still works just fine; I just cannot buy the original batteries as they were discontinued being NiCd 18V. The batteries have long since been scrapped and were discontinued in 2021. I have XR and Atomic 20V tools as well as one standard non XR saw I keep as a backup to the XR saw. I once had two packs and the drill was shipped with 1.2Ah batteries but I know DEWALT sold 4Ah NiCds at one point too.
Despite having the higher end tools, I still want to keep this one around for jobs I do not want to run my good XR drill on. I have the DCA1820 and 4x 5Ah packs (18650-based) and 2 PowerStacks (5Ah/1.7Ah), so I am wondering what the sweet spot for the older 18V tools is. I did look into a brushless 20V entry level drill on sale for the batteries, but I looked into that years ago before I got 6 20V batteries. I don't think that plan makes as much sense now unless I get some insane deal on a 20V Brushless with 2 2Ah batteries.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Just checking my math against the reality of the situation since the war over cheap TVs is coming up, and I can probably score a drill+impact+2Ah set on sale, or at least a brushless drill and 2x 2Ah packs for the $100 sweet spot should I need it:
On the original NiCds, you had 3 capacities if my research is correct:
  • 1.2Ah (base packs)/21.6Wh
  • 3Ah (Upgrade)/54Wh
  • 4Ah ("XR" range, but worked with the entire NiCd tool range without fuss)/72Wh
Now compare this to the 20V packs (which Dewalt confirmed is within the probable safe range):
  • 1.5Ah (Previous base pack, no longer sold best I can tell)/30W
  • 2AH (Current base pack/40Wh
  • 3AH/60Wh
  • 4AH/80Wh -- this is probably the "safe point" I should stick to if I don't want to tempt fate since it's MARGINALLY over the highest packs ever sold under the 18V system. 8Ah over is probably a rounding error.
  • 5AH (what I mostly own)/100Wh -- I can use these on my native 20V tools if 4Ah is the safe point and grab some 3/4Ah packs, while getting my initial replacements in a black Friday drill discount as "safe packs" I can interchange.
Beyond 5Ah is NR if I have the right information from DeWalt, but that's all I got from them. I don't think they have much information on the adapter with the NiCd tools because they assume people will upgrade to new tools as I did, but I also like the drill as a knockaround and always have; I can have my favorite 20V tools, and keep my workhorse 18V going this way.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I don't think you can use an Li-ion battery in this drill. It needs Ni-Cads. If you do an internet search for "dewalt dc970 replacement battery" you will find aftermarket replacement batteries for your drill for $20-$30. I had the same issue with an older Makita drill (which has more guts than the newer Dewalt drill) and the aftermarket batteries work fine.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
No. It’s known to take them with the DC970 paired with the DCA1820.
댓글 달기
답변을 추가하세요
Nick 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 25
전체 시간: 246
