Home button not working, but OK after OFF/ON or power attached
My wife's iPhone had sporadic issues with the home button not working, but after switching it off, then on again, the problem could be remedied. Also switching on when attached to iTunes via the cable worked. Now it has gotten worse to a point where the problem happens daily. At the moment, the most reliable way is to attach / detach the charger cable one or two times.
Apple official procedure (going to standby via standby button and waking it up via home button) doesn't work, neither does going into an Apple app and pressing home for a couple of seconds.
After it works again, there is no indication that home button hardware is at fault - when it works, the button is responsive everytime, no wiggling, no need for firm pressing etc.
Does it make sense to replace the home button under these circumstances? Could it be a power issue?
좋은 질문 입니까?
1 Comment
OK, just for everyone else: It seems to be a hardware issue with the button despite what I wrote.
The button works again after I plug in the plug, even if it is not yet connected on the other side. Obviously, the damage is so small that after the fix, it works for some time again even if you remove the cable.
Erik Koennecke 의
