주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Taylor Model C602는 McDonald's 매장 전용으로 Taylor에서 제조한 소프트아이스크림 및 셰이크 겸용 냉동고입니다.
My machine is on heat mode how do I stop it or how long is the heat pr
My machine is on heat mode and how long is the process or how do I stop it
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
선택된 해법
Hi @eric85243
Here's the user manual that may help.
On p.75 (p.77 of 114 pdf) it shows that there's 3 phases in the heat treatment cycle.
Up to 90 minutes for the temperature to reach the set temperature of 151°F and then it enters a holding phase to maintain the set temperature for a minimum of 30 minutes.
After this it enters a cooling phase, where the temperature must get to 41°F within 2 hours, after which it should go into either a standby or auto mode.
Overall it seems that the heat cycle can last about 4 hours.
The manual then continues to show what to do in the event of a heat cycle failure.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Yes but I do not want the heat cycle to go on, I want to by pass it as I am using raw milk for a reason!
의 공유
댓글 달기
Hey Eric,
It sounds like your machine is in cleaning mode. To stop it, try turning the machine off and then back on. That should get it out of heat mode. If it doesn’t, you might want to check the manual or reach out to Taylor support for more help.
Hope that helps!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Eric 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 20
지난 30일: 68
전체 시간: 1,592
