주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
퍼커션 마사지 건 출시일: 2020년 1월 7일 모델 번호: EM26 제조사: Toloco
If it will not turn on, what can I try doing to fix?
Bought this at a fair, worked good for about a week, feeling better, put in draw for about 2 years? Now wanting to use it, put charger on. When fully charges, went to turn on, wouldn't work. When on the charger show fully charged green light, on will not turn on! So wondering what I can do?
When turning on the switch no display, when plugged in the charger, windows display 99+, 0 showing for minus display! I seen no reset button, so I pushed in lightly the on switch. Power switch does not seem to be working!
Please let me know what I can try?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
I use the chargers light is green on the plug, but the massage gun doesn’t turn green and doesn’t have power What can I do?
의
댓글 달기
답변 1개
가장 유용한 답변
Hi @alanpeters29533
No display when on battery only and a display when the charger is connected, seems like the battery has failed even though there's an indication that it is charging/has fully charged. Not surprising given that it has lain dormant for 2 years.
Best option is to open the device and to replace the battery and then check if it works OK.
Here's the ifixit Toloco EM26 guide that will help to open the massage gun and here's a video that in shows how to test and replace the battery in a massage gun. The massage gun in the video may not be the exact same make and model as yours but it should be close enough
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Alan Peters 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 30
지난 30일: 155
전체 시간: 4,016
