주요 콘텐츠로 건너뛰기
2021년 9월 24일에 출시되는 9세대 iPad는 64 또는 256GB 모델로 제공됩니다. 모델 번호 A2602.
iPad won't charge or turn on after battery change
I replaced the battery in an iPad 9 and now it will not take a charge. Everything was functioning fine after with the new battery. Then a short time later it will no longer charge. When I connect a USB power meter it shows 0.01 amps. Nothing changes with a different charger and cable. Is this a board level problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
One of the most common issues with iPad repair is that the battery connectors on these are really easy to damage because all the pins are on the underside of the connector. And so they are often bent went trying to isolate them from making contact with the board.
The thinner pins on the far ends of the connector are used for battery data—that means your board may not be getting some sort of data it needs about the battery. So it may not be charging because it doesn't even think a battery is connected. Or that it thinks the battery is full, or it's just confused. Could be any of the above, but it's the first thing I would check in this case.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Julian 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 104
