주요 콘텐츠로 건너뛰기
Over ear Bluetooth headphones which have a magnetic switch on the right earpiece.
My right earpiece stopped working, no more sound
I have a Sennheiser pxc 550.
I wanted to use it, and realised one of the ear pieces wasn't making sounds. It's the right ear piece. I never connected it trough bluetooth to my laptop, so I was using the wire (the one that came with the headset) The wire goes in the right ear piece, if that matters.
I tried turning the headphones on and off. I connected the headphones trough bluetooth with my phone, still no sound from the right ear. I tried to reset my headphones next, witch didn't work either. I tested with another headphone both my laptop and phone, those work fine.
Does anyone know how to fix this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi there,
I've got the same problem, right ear doesn't work without any incident / any hurt.
I've tried thousand things, update mobile app, change settings, reset using the app, try BT or Wire, at the end I was ready to open it !
Finally... I reset all the settings manually and it works ! I read that you already reset the settings but did you try to do it manually ?
(as it mentionned at the end of the user manual)
Resetting the headphones to the factory default settings/Reset
1. Switch the headphones off
2. Press the voice assistant button for 4 seconds (near the ANC button)
https://www.manualpdf.in/sennheiser/pxc-...
Hope it will help
Thanks
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Nadja Van Landeghem 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 23
전체 시간: 51
