주요 콘텐츠로 건너뛰기
2.2, 2.4, 2.5, 또는 2.6 GHz Core 2 Duo 프로세서
759 질문 전체 보기
How to connect keyboard cable in MBP?
MacBook Pro 15" Santa Rosa
Well, I had a little problem with my keyboard a few weeks ago (could not type 'A') so I opened my laptop up according to MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Keyboard Replacement and cleaned the keyboard up (hoping it would solve that problem)... But then I could not figure how to "slide the keyboard ribbon back into the connector" so I'm left with a laptop without a working keyboard... I've tried stuffing it back in but it would only go in about 1mm, not enough to make the connection... any way to connect it back in?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
선택된 답변
It's a cam - it lifts up (very gently from the insertion end) you insert the ribbon cable then push the cam back down.
If this Answer is helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
how do i lift it up?
Get a magnifying glass, examine the connector. Lift up the black plastic flap holding the ribbon in place (vertical ) slide in the ribbon, press down the flap.
oh.. so it is opened from the back? haha ok i'll try again...
댓글 달기
가장 유용한 답변
See step #11 of the guide you used.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
the problem is that the guide does not show the outcome of flipping the flap up... anyone can post a photo of it? haha...
댓글 달기
Use tweezers, they help in get a little more of cable and then push it into the slot deeper)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
xkiller213 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,366
