주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2012년 GE Appliances에서 출시한 도어 접근 방식과 자동 제상 시스템을 갖춘 입식 냉동고, GE 냉동고 FUF17SV****에 대한 수리 및 추가 정보입니다. 이 페이지는 FUF17SV**** 패턴과 일치하는 모델 번호에 대한 정보를 다룹니다.
GE fridge works then it stops working again.
Hello my GE fridge is having some issue. The fridge works for couple hours then stops working. Then it's works for couple hours again then stops working for a while. What couple be an issue. I already cleaned the back also put new filter.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 5개
Define what you mean by "works" and "stops working".
That will help point to answers.
Otherwise, it is pure guessing.
의
So like for couple hours like let’s say 1-2 hours it works. Then it stop working for like 6-7 hours. And it goes on. And also sometime I hear it tries to start but it can’t. I had this fridge for 5 years. And we had the warranty for 5 years. As soon as the warranty wears off it started giving this problem.
의
@noname69736
Is this for the same freezer model as selected by the OP of this question?
I'm asking as the user IDs are different, i.e. your user ID and the OP who asked the question at the top of the page.
Moderator
의
Yes same user sorry I forgot the password for my other account.
의
@noname69736 of course it did. Everything does. Just a way to fill the dumps and make you spend your money.
The question I should have made clear was why do you thing it is working and why do you think it is not working.
의
댓글 달기
답변 1개
선택된 해법
Hi @noname69736 or @tanjina
When it stops what is the temperature in the freezer?
If it is 0°F (-18°C) then this is normal as it should turn off when the set temp is reached.
When it is off for a few hours, does it try a lot of times to start or perhaps only 1 or 2 times?
If a lot of times then it could be a faulty compressor start relay.
Disconnect the power to the freezer and then disconnect the start relay from the compressor motor and then gently, stress very gently, slowly shake it back and forth. If you hear it rattle it is faulty and needs to be replaced.
Search online for WR07X10121 (examples only) to find suppliers that suit you best. This is the GE part number for the relay.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Tanjina 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 11
전체 시간: 211
