주요 콘텐츠로 건너뛰기
Valve에서 2023년에 새롭게 출시한 인기 휴대용 게임 콘솔인 Steam 데크 OLED의 수리, 분해 및 문제 해결 정보입니다. 2023년 11월 16일에 출시되었습니다. 모델 번호 1030으로 식별됩니다.
There's a 1/4" White Line across the bottom of Newly-Replaced Screen
I recently replaced a cracked screen in my steam deck OLED (512 GB) and a white bar appears across the new screen when I boot it up. Everything else looks alright, if not a bit low-resolution. The white strip blocks out UI and gameplay that expect that part of the screen to be working. It does scale in brightness along with the rest of the display, and occasionally red and yellow horizontal strips appear inside that white strip
I have uninstalled, then reinstalled this screen three times trying to see if it was the connector and making sure the pins matched the instructional photo. This is the result each time. I would put my old screen back in to test, but it has been shattered and will not display anything. I am wondering if this may be a compatibility issue or if perhaps I received a defective screen replacement. Here some images of the display model#s in case that helps.
Old Display:
New Display:
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
did you get this resolved? i am having the same issue.
댓글 달기
답변 1개
선택된 해법
Hi there!
It does sound like a bad replacement part.
1 way to test, is to test it with another screen.
I would return the part and get yourself a new one! See if that fixed it. If the exact same issues comes up again, then you do know that it's something else. 1 way to make it easy, test with another screen!
If you have any questions, please let us know!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Austin Van Haitsma 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 48
전체 시간: 206
