Getting too hot after sim card insert
iphone4s 32gb white . it getting too hot when i put the sim card insert . it only remain in searching mode and battery is draining very fast like in 1 min 6% drained and get too hot from battery jack and the near by and middle bezel also from below the sim card . before it was working fine. it was dropped on the floor but working after accident . it worked for approx 6 days. now showing this symptom .
좋은 질문 입니까?
댓글 4개
My frnd checked the Battery terminals. He said this iphone is shorted. He checked some tracks it shows fully shorted . baseband ic is getting so hot while it uses the sim card. without sim card it running perfectly. anybody know where to start the checking of shorting ?
SIMRAN 의
i got the same problem !!! on a 64 gig
jimtsolakakis 의
not being funny simran, but why would a shorted battery give you problems when the sim is inserted? I'd be looking at antenna/sim problems as this seems to be when the problem starts. If sim is inserted but in aeroplane mode do you still get the drain?
pollytintop 의
in aeroplane battery is not draining . when i turn off the flight mode. it remains in searching always and getting hot.
SIMRAN 의
