메인 콘텐츠로 스킵하기
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
254 질문 전체 보기
checked everything and still no power
have checked power to everything and still no power, its not the door switch because the inside light is not even on, and the themal switch is good, and i have power to the dryer everywhere it just will not do anything, please help
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
3개의 답변
가장 유용한 답변
Try unplugging it for 5 minutes to reset it, then plug it back in. Remember an electric dryer runs off of two 110 lines in the USA. So throw both breakers at the breaker box to be sure it's getting full power.
해당 답변은 도움이 되었습니까?
점수 3
의견 추가하세요
Your drum light is not a good indication that the door switch is working. Actually, if your door switch is not working, your drum light will not receive any power. Check the wiring diagram on your original question.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
Tried everything you recommended and still nothing. Surly someone has solved this problem. Who has the answer. Percy 601-638-1646
Update
checked power to dryer, thermal fuse, door switch all ok. this dryer was working fine one day and nothing the next. No lights or anything just dead.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
What symptoms does your dryer have? What have you tied so far? What have you checked?
의 답변
If you already checked all the parts and found them to be in working condition, I recommend a new control panel assembly.
의 답변
How do you test a control panel board, My unit has exact same problem and board loos to the eye as good as new. gordo89120@gmail.com Control board is expensive $180 on Amazon, though it is an easy repair. But costly if that is not the problem.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
kory hentges 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 1,615
