주요 콘텐츠로 건너뛰기
9월 20일에 출시된 가장 크고 비싼 2019년 Apple 스마트폰으로 6.5" OLED 디스플레이를, 트리플-렌즈 카메라 시스템및 크게 향상된 배터리 수명이 특징입니다. iPhone XS Max의 후속 제품입니다.
iPhone front camera not working after battery change
Hello everyone, as the title states: front camera stopped working after battery swap. Face id works tho, whenever im on camera app i can do photos with my rear camera just fine, but when I try to use front camera everything laggs and just goes back to rear camera mode. The phone has changed screen (but everything was fine after that so i don't think its the problem). Please help;(
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
If the front camera stopped working after a battery replacement, but Face ID still works, it’s likely a connection issue rather than a hardware failure. Here are a few things to check:
1. Reseat the Front Camera Flex Cable
Since the front camera and Face ID share the same flex cable, it’s possible that the camera’s connection is loose. Try carefully reconnecting the front camera flex cable to the logic board.
2. Check for Damage to the Flex Cable
If the cable was stretched, bent, or torn during the battery replacement, it could be damaged. Inspect it closely under good lighting.
3. Clean the Connectors
Use 90%+ isopropyl alcohol and a soft brush to clean the connectors on both the logic board and the camera flex. Make sure it’s fully dry before reconnecting.
4. Check for Software Issues
• Force restart: Press and quickly release Volume Up, then Volume Down, then hold the Power button until you see the Apple logo.
• Check for updates: If the phone is running an outdated iOS version, updating might help.
• Reset all settings: Go to Settings > General > Transfer or Reset iPhone > Reset > Reset All Settings (this won’t erase data).
5. Try Another Front Camera Module
If nothing works, the front camera module may have been damaged. Try replacing it with a known working one (but be careful—Face ID won’t work if you replace the entire Face ID sensor assembly).
Did the issue start immediately after the battery swap, or did it happen later?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
StojakNaKomputer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 34
전체 시간: 281
