2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
1503 질문 전체 보기
Battery won't charge yet Sync works and icon shows connected to power
Hi
I have been repairing an iphone 3G that was damaged and given to me. I replaced the power flex cable as the old one was broken. I also replaced the back casing and battery, as well as a cracked screen.
My problem is that now the phone will not charge. Initially I had placed the 3Gs battery in the phone with the 4.51 watt hours. I beleived this was the problem so I have since replaced the old batter. Same problem. Iphone syncs with PC no problem and battery was powering phone until it went flat. Also the battery icon changes to the lightning bolt when connected, but like I said it does not charge.
Appreciate any suggestions.
Perhaps I have damaged the mainboard with the 3Gs battery, yet I'm presuming it is all connected correctly as sync works and battery was powering phone.
Thanks
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
Jason, check the fuse shown in the image. Test it for continuity.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Thanks,
Think I need a magnifying glass, how will I tell if it is broken? test for continuity, and how if broken can I fix it?
의 답변
have you ever changed the dock connector in all this repair?? might be worth a clean or a look. Also check the very small fuses/inductors on the area near the "do not remove" sticker .
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Jason 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 371
