주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair and disassembly guides for Epson printer. The company was founded in 1942 as Daiwa Kogyo, Ltd., but merged with another company in 1959 to create Suwa Seikosha Co., Ltd.
epson printer won't print color
Hi my Epson Printer ET 2800 won't print color, from few days. Problem come after several several cleaning cycles and I did not want to waste anymore ink. I cleaned the heads by injecting a cleaning solution through the ink feed ports per videos. Black works fine, but none of the 3 color heads will print anything during a nozzle check. No spots, nothing but blank sheet where CYM should be printing. Cables to the head look fine. Any suggested causes or fixes?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
I have run the nozzle check several times the black works fine but there is NO color from any of the other three banks. All of my colors are full.
댓글 달기
답변 1개
선택된 해법
If you are facing this problem then tried the solutions you are telling then you should try using the new ink cartridges. Plus, check the printing settings are set to color, and perform the power cleaning. Besides that, look for the additional help could also be helpful to fix it easily.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Charles Smith 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 17
지난 30일: 73
전체 시간: 703
