주요 콘텐츠로 건너뛰기
천장, 상자, 타워 및 스탠드 팬/선풍기를 포함한 모든 가정용 기계 팬/선풍기에 대한 수리 안내 및 지원.
175 질문 전체 보기
Why the motor wont turn and fan will not come on.
When i plug in my Aloha Breeze tower fan nothing happens
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 6
2 댓글
I have a lasko stand fan and it won't turn on anymore.
Mara fan kharab ho gaya hae
댓글 달기
답변 4개
선택된 해법
viviannash17, there are a few different variation of this fan. I can tell you that the model 84001 has a fuse as well as a capacitor that connect to the motor. I would disassemble the fan and check those two items. Of course, make sure that you disconnect the power, and that you know how to use a multimeter. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 8
3 댓글:
I have a portable fan that can use the power from an outlet to run the fan so it doesn't used the battery and charges it instead. Suddenly my fan switch doesn't want to switch to AC mode which was the mode were you can use the outlet instead of the battery. I tried to turn it on by moving the switch in small inches between sides. But it still bothers me. Can someone tell me what's the problem?
I have a stand fan i check motor is good, lubricated the bushing/shafting and already replaced the capacitor (capacitor is 2 microfarad) but still i need to push the blade to start it or start turning. What is the problem of the fan
@ANTHONY FERNANDO possibly secondary motor winding. We would need to see more and know what make and model your fan is
댓글 달기
Most of the time, the problem is the motor start capacitor, this brief video explains:
Fan blades don't spin
It could also be due to the termal cut off fuse, or the electric motor itself (uncommon). For a complete repair analysis video, watch this:
Complete electrical fan troubleshooting guide
해당 답변은 도움이 되었습니까?
점수 5
댓글 달기
You may have two bad switches. I just changed two because they went bad at the same time. Very easy tofix. Just make sure you get one for the fan and one different for the lights. Different amps for both.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
If the fan has a sleeve bearing and it has positioned at inclined angles for long periods of time, 1000+ hours of usage in this manner, the internal rotor will warp due to un even and insufficient lubrication as well as a buildup of carbon byproduct and the motor will eventually seize without much warning. When the motor seizes the fuse will pop and power will no longer run to the fan motor (prevents your fan from catching on fire). You will need a new motor and a new fuse, but the fan speed capacitor should be fine.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
viviannash17 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 27
7일 전: 188
30일 전: 792
전체 시간: 219,683
