4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
3267 질문 전체 보기
Why is my iPhone 4 flickering after I replaced a home button?
why is my iphone 4 screen flickering after i replaced a home button?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
Sounds like you may have damaged something on your way in when you replaced the home button.
I would start again, using this Guide to disassemble the phone and then ensure that all the cables and connectors were in tact and undamaged.
Then I'd clean the phone as instructed to ensure no oils from your hands remained.
Then I'd put it back together very carefully and hope it worked.
If the problem continues to persist or you find that you've damaged something, you'll have to replace it before the phone will work properly again.
Hopefully the damage isn't too severe and it remains salvageable.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
sergeybat 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,024
