PS4 Burning/Plastic Melting Smell
좋은 질문입니까?
Hi! Is something burned? Or is this not the case? I recommend to open it, and take the power supply out. Please check this one if the burning smell comes from there. Most of the time, this is the case and need to be replaced. Also check the drive and motherboard.
If you need guides, please let me know!!
이 답변이 도움이 되었나요?
Hi there. Not sure if you can help, but I was playing Days gone and I saw a coloured screen before it shut down and a burning smell from vram chips. Is it likely the power supply? Power supply doesn't smell burnt. Thank you IA.
Hi!
Probably it came from the motherboard. Please check if you can see anything that is burned there!
Hi there. Just now seeing your comment. So the only thing that smells a bit burnt is the 4 pin cable that runs from the PSU to the motherboard. I'm not sure if it's dangerous to put my machine back together and try it. I was waiting for new thermal pads to arrive, but having second thoughts as I don't really want to start a fire.
Thank you
You can replace the cable just to be sure. They are not that expensive and easy to do!
Thank you for commenting.
지난 24시간: 3
지난 7일: 6
지난 30일: 41
전체 시간: 103
댓글 2개
You will need to go through this:
PlayStation 4 Teardown
and look for damaged capacitors
Jade 의
Thank you for your comment
aaron boschman 의
