주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1502 / 2.4, 2.6 또는 2.8 GHz 듀얼-코어 Intel 프로세서 / 2013년 10월 출시
Doesn't charge battery, yet it implies it is
@danj
Hi Dan, not sure if you will see this post, just joined the 'ifixit' hub. I have a problem with Macbook Pro A1502 model - late 2013 - battery needed replacing and was left unattended and uncharged for previous 3 months - connected to magsafe charger yesteray and although the machine stated to charge it then subsequently will not take any charge - i have tried disconnecting and reconnecting, resetting SMC etc all to no avail, the charger light goes green when connected to macbook, no orange light ... and a strange ckicking noise is coming from keyboard area when i press and hold start button - any advice ?? i am a bit lost... many thanks Giles
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
@giles94589 - Let's see if we can get a bit more diagnosis of the problem, install this gem of an App CoconutBattery take a snapshot of the Apps main window and post it here so we can see what's happening.
@danj - Hi Dan, Thanks for getting back to me ! re installing 'CoconutBattery' not quite sure what you mean .. as macbook totally dead and can't install anything ..?? the only thing that shows anything is the green light on macsafe charger connection ...that should be orange if it was working... otherwise no other sign of life, screen completely dead and a clicking noise when i press the power button....
@giles94589 - FYI - You don't need to make multiple postings for the same problem. If you have a second system with a different issue that makes sense to post it independently. We try to keep the systems unique so others can find things.
댓글 달기
답변 1개
선택된 해법
@giles94589 - Well that takes the Cake!
So... that means you need to try a new battery as SMC is locked up. Using it to restart the system and then reconnect your battery after doing a clean shutdown. A good Mac tech can also apply power to the logic board power rail as well instead. Even still that assumes there is nothing else wrong.
Given the age of the system it likely needs a new battery anyways MacBook Pro 13" Retina (Late 2013-Mid 2014) Battery and here's the guide MacBook Pro 13" Retina Display Late 2013 배터리 교체
Replace a 6600 mAh battery compatible with MacBook Pro 13" Retina Late 2013 to Mid 2014 A1502 model laptops. 74.9 Watt Hours (Wh). 11.42 Volts (V). 이미지
제품
$89.99
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Dan, thanks very much for your help, need to find new battery .... cheers Giles
댓글 달기
답변을 추가하세요
Giles 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 10
전체 시간: 85
