주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides and support for Nespresso Inissia coffee machines.
Machine not piercing the capsule—water leaks out the back
Hello, After placing the coffee capsule and firmly closing the capsule compartment (capsule holder), I activate the machine. The water is pumped, but it escapes behind the capsule into the used capsule container (capsule bin). I open the compartment and see that the capsule has not been pierced—neither from the front nor the back. What could be the cause of this issue?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
The capsule should already become pierced by the three needle from the back in the moment you fully close the lid/leve, i.e. before activating the machine and pumping water.
If that is not the case, then those three "needle" in the back of the brewing chamber may be worn out.
Which capsules are you using?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Patt Z. 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 13
전체 시간: 67
