주요 콘텐츠로 건너뛰기
Will not charge fully or at all sometimes.
I recently received a iBook G4 from a friend, they did mention that the battery wasn't great. After a few months the machine wasn't charging fully. It seemed the connector for the charger wasn't working properly so I purchased a new one. Since I have been using the new one it doesn't charge fully, or its shows its plugged in but not charging, or when it is plugged in its not recognizing that it is. Is it a problem with the battery or with the connection?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
Download Coconut battery and it will tell you the remaining capacity of the battery. http://www.coconut-flavour.com/coconutba...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
The only way to be certain is to use a different battery in your computer or use your battery in another computer. I think it is probably the battery. Ralph
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Rereading I'm not sure if you meant you replaced the power adapter or the dc in board. If you replaced the adapter you might possibly have a bad dc in card. Ralph
댓글 달기
귀하의 답변을 추가하세요
Alex 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 581
