주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung A40 Sea Salt Water Damaged. -Photos and Video Included!-
Hello, I have a samsung a40 that fell in salt water at like December of 2023. I tried to fix it in mid 2024 but I got no signs of life. Today, which I have more tools than then, I tried to fix it again. I took off the shields off the chips and cleaned everything with 99 percent alcohol and an ultrasonic cleaner with distilled water. After replacing battery and charge port and sub-main cable, the phone draws 0.00 amps and a high pitched noise comes off the mainboard. No vibrating and no speaker, and no screen sign.I have a lot of important photos on there that I would like to save. Does anyone know if this phone is saveable?? And if it is, how should I proceed??Please answer it is very important!! Thank you.Here are some photos of the main board and a video of the high pitched sound when charging:
이미지
이미지
이미지
이미지
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개
which country are you in
@tech_ni Why does that matter?
@tech_ni I'm EU though, southern east
@giant474 because if you wanted someone to look at it for you and you were in the uk i could of looked at it for you
댓글 달기
답변 1개
선택된 해법
Hi @giant474
Here's the troubleshooting guide that may help.
Go to p.11 (of 54) and follow the Power on flowchart and see how far you get through it.
Use the search function in your browser to find the location of the components shown in the flowchart in the board layout diagrams in the guide - see p.9. You will have to zoom in a lot to see them.
Hopefully a start.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
@jayeff Thanks a lot for this but just today I desoldered the pmic and it had a lot of corrosion under it so it's probably that most ics are corroded underneath unfortunately. I might have to buy a functional main board and just transfer the 2 main chips over (cpu and the storage one). Again thanks a LOT for the help.
댓글 달기
답변을 추가하세요
giant474 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 30
전체 시간: 304
