주요 콘텐츠로 건너뛰기
Model No. A1367 / 8, 16, 32, or 64 GB capacity
914 질문 전체 보기
My EMI shield is stuck to the logic board.
The metal EMI shield appears to be deliberately adhered to the logic board. How would I go about separating this and how would I remove the excess adhesive from the logic board. I have some pictures below. Please help ASAP as I am on a timeline. Pictures are in the link below
http://s1079.photobucket.com/albums/w509...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Yes, there is adhesive that holds it there. If you can, carefully and slowly lift the metal shield while holding the logic board down on the small piece that you can see on the side by the volume buttons. Be very careful to gently but firmly lift it. You will hear that adhesive start to give as you slowly separate them more and more. Be careful as you can easily tear the power button/volume button flex cable.
If that doesn't work, try using a heat gun to warm the plate slightly. It will help loosen the adhesive.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thank you very much. Is there any way to remove the excess adhesive from the logic board, or should I just leave it there?
댓글 달기
귀하의 답변을 추가하세요
Dean Lipinski 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 896
