combo drive won't eject disk
replaced drive and have the same problem
좋은 질문 입니까?
I would suspect a bad optical drive ribbon cable. The cable on this iBook G4 model is fragile. Remove the optical drive and check the ribbon cable silver contacts (the side that connects inside the logic board socket). Check if the contacts are all well aligned and not damaged. If so, replace the ribbon cable.
해당 답변은 도움이 되었습니까?
+ Ralph
Have you tried shutting off the machine, then booting while holding the trackpad button down? That should tell the machine to force the disc out.
해당 답변은 도움이 되었습니까?
I've tried rebooting with the trackpack held and have reset the PMU.
해당 답변은 도움이 되었습니까?
Is this the exact same problem you had before you replaced the drive? Where did the new drive come from?
same problem as I had before replacing with iFixit drive.
해당 답변은 도움이 되었습니까?
Do you mind telling us what that problem was? It seems it might not have been the drive.
Is the disk catching at the case? Maybe its a simple misalignment.
The disc won't eject from the drive
해당 답변은 도움이 되었습니까?
has nothing to do with the hard drive. I don't think I can help you.
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,935
Can you give us a history so that we've got something to work with?
mayer 의
