주요 콘텐츠로 건너뛰기
Repair guides, service help, and troubleshooting information regarding Hitachi refrigeration units.
Condesner Location on Hitchani Refrigerator
Hi,
Can anyone guide me on where the condenser location is on the Hitachi R-T380ES1KV refrigerator? I have checked at the bottom, in the compressor compartment, but it's not there.
It is also not mentioend in the service manual. Any had an experiecne about it?
Thanks in advance.
Regards
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @mohsins
Not sure regarding the model you posted but in some Hitachi refrigerators they have what is called "heat radiation pipes", either at the back or on the sides, on the inside of the cabinet walls.
When the compressor is running, check if the back or a side wall feels warm or even hot. If it does then most likely that's the system they're using to release the heat from the sealed system and not a condenser coil or unit. Basically, not meant to be removed.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thanks for your time and guidance.
댓글 달기
답변을 추가하세요
Mohsin.S 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 36
