주요 콘텐츠로 건너뛰기
Why has my laptop gone on a boot start up loop
My laptop has gone onto a boot start up loop and I don’t know how to sort it.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @leoyork57849
If Win10 (or Win11) is the OS when it starts to boot into Windows, press and hold the Power button operated to force stop the laptop and shut it down
Do this 3 times in a row i.e. start → boot → force stop → start → boot → force stop → start → boot → force stop.
On the 3rd attempt it should boot into the Windows Recovery Environment menus.
If it does go to Troubleshooting → Advanced → Startup repair and follow the prompts.
If you can't get to the WRE menus try using a Recovery disc to resolve the problem.
You can create a recovery disc from any known working Win10 (or Win 11) PC. All you need is a 16GB (or 32GB for Win11) USB flashdrive and 1-2 hours of time.
In the host PC go to Control panel → Recovery → Create a Recovery disc and follow the prompts.
When you have the recovery disc, insert it into a USB port in the laptop and turn it on. Press the Esc key repeatedly and then press F9 to change the boot order to USB as the 1st boot option.
The laptop should boot from the USB drive and not the laptop's drive (HDD or SSD) into the WRE menus.
If it does follow the procedure as above to repair the startup.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Leo York 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 32
