주요 콘텐츠로 건너뛰기
2019년 11월에 출시된 MacBook Pro 16''의 수리 안내서 및 분해 정보입니다. 모델 A2141, EMC 3347.
battery not detected ,fan at 100% spin,lagging
Hi. ok..i try to put new paste on logic board.but... obviously mine mistake what happen.. i disconeccted all connectors but didn't mine battery and in middle of process MB turn on..and i didn't know how to turn it of untill 30 sec he do it.after i assembly again, mine battery won't work and appl os can't see it in system report.also, fans are at 100% and all is lagging.tryed to reset smc but no help.any help would apreciate..thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
This looks like the battery board data cable is not properly connected into the ZIF connections. Review Steps 9 to 14 in this guide MacBook Pro 16" 2019 배터리 교체 take note on the way the ZIF connectors work and make sure the cable is not damaged here's the replacement MacBook Pro 16" BMU Flex Cable
이 답변이 도움이 되었나요?
점수 2
댓글 9개:
ok,will check the cable and order.new one.But can u explain me is there a chance that something else is broken,sine MB suddenly by himself turn on while i was doing that?If i remember after the last one of the right side cables disconnected ,he turned on and,since i didn't know how to turn it off,he did it by himself 30 sec after,and in that stage fan eas spinning fully if I am remembering correctly
i mean, can battery in that short period of time be broken somehow? it was 75% of battery capacity,and 240 cycle
@icyeye - The battery is not the focus here as the communication between the battery to the logic board is not present (that cable). Your screenshot shows the battery is not talking to the logic board.
While you should have disconnected the battery before taking things apart. So you could still have issues but we need to solve the obvious issue first.
Start by checking the ZIF connectors if the latches are correctly set.
ok.i edited post and add the picture. maybe u can see if there is something wierd. i only detached the right side of the cable...
@icyeye The cable is not fully into the ZIF connector, read again the guide step mentioned above and take it slow and gentle. The cable needs to be fully inserted so none of the gold traces are visible. Gently lift up the latech, thread in the cable, lock the latch.
댓글 4개 더보기
댓글 달기
답변을 추가하세요
icy eye 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 59
