주요 콘텐츠로 건너뛰기
Game Boy는 1989년 4월 21일 일본에서 출시되었고, 1989년 7월 31일에 북미, 그리고 1990년 9월 28일에 끝으로 유럽에서 출시되었습니다. 커다란 회색 케이스와 모델 번호 DMG-01이 특징입니다.
Red light turns on but device won't boot
I have some experience repairing gb's but never encountered this before..
The gameboy turns on (the red light turns on) but won't boot, no sound, no screen
BUT when I remove a battery (while I leave the console ON) and put the battery back in place now it 100% of the time boots up the game.
Any suggestions?
Contacts are cleaned, speaker replaced, vertical lines fixed, contrast/volume wheel/OnOff button are all working
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi!
Probably related to the board without the screen (so with the battery springs on it).
Maybe some trace is damaged there by the acid from batteries.
How does the board look? Still fine? Did you found corrosion before you cleaned it?
I would replace that board and see how it goes. The issue should be solved by then.
If you want to repair the board, please check and test all the traces.
Please let us know how it goes!
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
Hey, It works perfectly with the back board of a know working gameboy. But I sadly don't have spares to replace this.
I will have to do more investigating then :)
Yeah, the fault is somewhere on the back board unfortunately... You can run a continuity test with a multimeter. Test both ends for the traces, if you get a beep, the trace is fine. If not, you need to repair it or run new cables to both ends. It take a lot of time, but it's the only way I guess...
i have this exact issue and it has puzzled me for months ive reflowed every solder point i could find and also bridged the power switch and dc jack so they would allow it to work if they were corroded. Ive also recapped everything on the main board the lcd works fine ive tested it on working motherboards without issue and whats weird is that the console boots up whenever i short ground and vcc before that its not giving the proper voltage but after i short it everything works perfectly.
댓글 달기
답변을 추가하세요
Bram Neyens 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 33
