Some of my faucets run and some dont
My kitchen sink doesn’t run, but the dishwasher water runs fine. One faucet in my bathroom doesn't run but the shower and faucet in the other bathroom runs fine.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Hi @kanedale
Turn off the water at the main supply faucet for the premises and then remove the relevant faucet spindle and then have someone else turn on the water again and check if there's any flow from the pipe - be aware if water does come out not to cause a flood, get ready to quickly turn it off at the mains ;-)
If water flows out of the pipe in the sink and also the bathroom ( is it a shower or basin?) check that the faucet washer in the faucets are all OK ,i.e. not binding - moving freely in the spindle
Is it both faucets in the sink i.e. hot and cold water or is there a flick mixer faucet installed?
If a flick mixer, are both the hot and cold water affected?
If it's a shower in the bathroom that's affected have you checked that the shower rose is not blocked?
If there's a screen filter in the end of the kitchen spout have you checked if it is clear?
If no water flows out of the pipes then they're either blocked or not connected
댓글 달기
