주요 콘텐츠로 건너뛰기
The Xtreme 2 is a large portable Bluetooth speaker, released in January 2018. This Speaker comes with an IPX7 and up to 15 hour battery life. Model: PL
Power button only works sporadically when on battery
I have a JBL Xtreme 2 music speaker where the on/off button only works sporadically for turning it on.
When it finally is turned on the button always (as in 100% if the time) works when turning it off.
If the speaker is plugged into an outlet using the charger the button instantly turns on the speaker.
So to recap: When wanting to turn the speaker on when it runs on battery, the button only works sporadically - as in I have to pres the button 3 to 10 times before it turns on. The button works 100% of the time for turning it off or for turning it on, when it is plugged in via the charger.
Once the speaker is turned on the battery can keep it playing for hours and hours... So I do not see this as a battery issue.
The speaker has always been used in our bathroom sitting on top of a closet furthest away from the shower, so it has been exposed to some moisture.
Any suggestions as to what the cause could be?
ChatGPT suggested a slightly corroded connection on the power on button - but would love to hear from people here as well.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
This can be cold solder joints. If you were using the speaker in bathroom I recommend to check that solder points and maybe put on a new tin with flux. This could help.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thanks Jakub. Yes, makes sense.
I just tried disassembling it - and had to give up. Was worried I would mess something up. No easy access to get a good look at the cable for the on/off button.
I used a Youtube video as inspiration for disassembling it - but apparently my model has had glue added, so the speakers can't be removed even when all screws are removed.
If anyone has done something like this for the Xtreme 2 before, I am all ears.
댓글 달기
답변을 추가하세요
Esben Rasmussen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 22
전체 시간: 22
