My Xbox won't update at all even when using my Hotspot
It keeps saying a wifi error code
좋은 질문입니까?
좋은 질문입니까?
Hi!
It’s just a generic error that it can’t update your Xbox.
When the wifi chip is broken, it can show you the error, the error can also occur if your HDD is broken, or disc drive.
It’s difficult to say…
When you try to cancel the update, does everything work??? Before you did the update, did everything worked correctly?
If yes, I would first replace the HDD and see how that works..
이 답변이 도움이 되었나요?
I had to put a new cd player in it and I did kinda break a small little pin in the wifi card so it could or the hhd
I'll test them in a few days but thank you for the information
My pleasure! If something did break on the wifi card, I would replace that one anyway and check if the error is gone. If not, then you might want to check the disk drive or HDD!
지난 24시간: 1
지난 7일: 3
지난 30일: 22
전체 시간: 21
댓글 1개
It says system error: E100 00000703 80910006
Casey teska 의
