주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GameCube는 Nintendo의 네 번째 가정용 게임기입니다. 수리는 간단하며 일반적인 수리 도구만 있으면 됩니다.
GameCube light is orange, and disk not spinning and no picture
When i turn on my GameCube, the fans starts spinning and it displays an orange light. the problem is the disc is not spinning and there is no video output. i am using a a/v to hdmi converter. my gamecube is ntsc us
Update (11/19/25)
EDIT: ok so video works my av to hdmi adapter just sucks. the disc drive is now the only problem. the screwdriver hasnt arrived yet so i will update soon when it arrives and i have taken a look inside
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Glad that that issue is fixed now! Only the drive for now that need to be fixed!
의
댓글 달기
답변 2개
가장 유용한 답변
Hello, the only things i found about this issue are all related to the GameCube not being able to read the disc, so I'm just going to assume that's the problem here.
First, the disc laser could be dirty, which can prevent it from functioning properly. Cleaning it carefully might resolve the issue. Another possibility is that the laser was knocked loose; realigning it carefully could fix it. Additionally, checking for any faulty connections inside the GameCube could help identify the problem.
이 답변이 도움이 되었나요?
점수 1
댓글 5개:
so should i open it up?
의
If you are comfortable opening the Gamecube, go ahead. I'd personally watch a tutorial on YouTube, so you don't accidentally damage it.
의
the screwdrivers arrived and i took out the disk drive, what next
의
ok i flipped a lever and it started spinning but when i let go of the lever, the lver goes back and it stops spinning
의
Hi!
Yes this is normal!
So it does sound that there is something with the lever!
If you hold it, does it read it correctly as well? If yes, then the laser is fine!
I would replace the lever completely and see how that works out :)!
의
댓글 달기
Hi!
Cleaning the laser is a nice first step! You don’t need to open it for this.
What also could be thing is the sensor. Which is located on the drive. Could also be the laser which is faulty OR the capacitors which failed…
Unfortunately, there are multiple components that can cause it.
To give you a idea how to replace the laser: Nintendo GameCube 광학 레이저 렌즈 교체
I would check if the sensor isn’t broken and still look fine. Try to manually press the lever on the sensor and see if something happens (when you took the top case off).
If you are not sure, you can sent some pictures to us.
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
the lens isnt moving. could that be the problem?
의
Hi!
Could be the laser that simply won't detect the disk. Could be the sensor (only way to find out is to open it up).
The capacitors are less likely, because the Gamecube is trying to read at that moment.
의
i will message again once the gamebit screwdriver arrives. thanks though
의
My pleasure! Good luck with the repair and please let us know how it goes!
의
댓글 달기
답변을 추가하세요
oddo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 16
지난 30일: 93
전체 시간: 1,153
