주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
New Nintendo 3DS XL로 알려진 Nintendo 3DS XL 2015년형은 2014.10.11에 일본에 출시되었으며 북미에서는 2015.2.13에 출시되었습니다. 대한민국에는 2015.5.1에 출시되었습니다.
Why is my New 3DS XL always have blinking red lights?
I have a new 3DS XL and recently, I accidentally dropped it on the carpet. After opening it up to check its state, I have been having blinking red battery light. Having said that, the device can be played for hours. Tried to charge it but, while it does, the battery light only changes to continuous red and the orange charge light does not turn off to show battery is fully charged.
I read many posts on potentially similar issues. I tried to recalibrate the battery to see if it would resolve the issue but it didn’t work.
I also got a new battery but the situation remains the same so, it sounds like a hardware issue (?)
Any help would be appreciated.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi!
Weird issue. You don’t hear that one often!
If another battery is having the same exact issue, it’s probably something else…
I would open it up and check all the cables and connections, are they still fine??
How are the battery pins? Still good? Not damaged?
Would also clean the battery pins and motherboard with isopropyl alcohol.
You can also test another battery just to be sure.. if the same issue persist, you might want to check or replace the motherboard..
Please let me know if you need any guides!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Tim 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 8
지난 30일: 34
전체 시간: 342
