주요 콘텐츠로 건너뛰기
The Makita SP6000K1 is a 6-1/2" circular saw with a 55" guide rail system, featuring a 12.0 AMP motor and variable speed control for versatile cutting in various materials, with a maximum cutting capacity of 2-3/16" at 90° and 1-9/16" at 45°, and bevel capability from -1° to 48°.
Why the saw can run but there is no cutting strength
The saw can run but when cutting something it has not powerful enough, no cutting strengths.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
This is what AI has to say using a simple search: A 12A AC motor lacking power can be caused by electrical issues like low voltage, open windings, or a bad capacitor, as well as mechanical problems such as worn bearings, overload, or a lack of lubrication. To diagnose the issue, check the power supply, test the windings and capacitor, and inspect the bearings for proper lubrication and free movement. I would start with a capacitor if it has one.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Xiongwei Rong 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 13
