How ro replace ac compressor on my truck
How do I go about draining the freon in the ac compressor so I can take the old one off and replace it .also when I recharge it can I go to advanced auto and get a can of that freon or what ,any answers will be very helpfull and appreciated thanks
88 chevy silkerado
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
선택된 해법
To properly evacuate the freon, you need a machine that pumps the freon out of your A/C system and recycles it for future use. After that is done, you can replace the A/C compressor. I would also recommend flushing out the lines and replacing the dryer (especially if your compressor failed and put some debris into your system). After repairs are completed, the refrigerant recycling machine is again used to remove all of the air from your A/C system, then it pumps the correct amount of freon & oil back into the system.
If your system already has a leak, then there is no freon left in the system to pump out. You can install your new compressor and proceed with the evacuation & recharge steps.
If you don't have access to an evacuation pump, then you should take your vehicle to a qualified A/C shop to have that step completed.
Hope this helps,
BILL
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
귀하의 답변을 추가하십시오
shawn 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 9
전체 시간: 4,079
