주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
3MB 공유 L3 캐시 1.8GHz 듀얼-코어 Intel Core i5 (Turbo Boost 최대 2.8GHz)
397 질문 전체 보기
Can I upgrade the ssd of the mba 2012
hi may i know for the latest mba2012 we can upgrade the 128gb ssd to 256 or 512 gb ssd ourselve? and how about the macbook pro retina 2012 for the same questions from 256gb to 512 gb ssd?
2. if yes then can u recommend what brand of ssd we should get and anything we need to take notice before we buy the ssd?
Thanks and best regards : )
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
의견 추가하세요
답변 5개
선택된 해법
Hey!
The MacBook Air and the MacBook Pro Retina both use custom connectors.
There have been fitting SSDs for older MacBook Airs around, but Apple changed the design of the connector with the 2012 model. You should also note that the SSDs of the MacBook Air and the MacBook Pro Retina are not interchangeable.
Chances are however good that there will be compatible drives for both machines in the coming months.
Long story short: Currently NO, in a few months PROBABLY YES.
해당 답변은 도움이 되었습니까?
점수 4
댓글:
Thanks senthor for ur good info!!!
Thanks, good info for me too.
의견 추가하세요
OWC are now selling SSDs for the newest MBAs! Check out this link: http://eshop.macsales.com/shop/SSD/OWC/A....
If the link doesn't work, google OWC for more info. Hopefully, OWC can provide upgradeable SSDs for the MBPRs!!
해당 답변은 도움이 되었습니까?
점수 4
의견 추가하세요
When you upgrade the SSD, is it additional to what you already have? Or are you replacing the current SSD? thank you.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
Its a REPLACEMENT drive. There are external adapters/housing to use the SSD module that you remove as an external drive (super fast one). Probably worth it for a 128GB SSD class usb 3.0 external disk that fits in your pocket. OWC also makes that adapter (part of a kit too).
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
Anyone who have done the upgrade for the mba? I have heard different things about the quality, and some problems to get it to fit...
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
lsgan 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 43,089
