I need help with fixing the head gasket valve
So i've been working on a quality farm and country head gasket and in the big piston inside theres a little gap at its edges. Is that bad or should i replace it
좋은 질문 입니까?
좋은 질문 입니까?
It is normal to have some "gap" at the top of the piston. The rings make up the difference in size and seal between the piston and the cylinder wall. Here is an example picture:
http://www.rlengines.com/tech/rings.jpg
What was the original problem that lead you to tearing the engine apart?
BILL
해당 답변은 도움이 되었습니까?
Bill, click on Juan icon to see his other questions on this mower. If nothing else, he's persistent.
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 374
댓글 3개
now you need to tell us who built the engine for your mower. It is definitely an AYP and if it is the same mower as from your other question, we know its a 16.5 HP. Is it B&S or Kohler or anybody else?
oldturkey03 의
B&S it is the other one
Juan Hernandez 의
when you turned it on a lot of smoke blew out and it would turn off, so we're changing the head gasket valve. And hopefully that's all we have to do
Juan Hernandez 의
