주요 콘텐츠로 건너뛰기
Apple의 MacBook Pro 노트북 라인은 전문가 및 파워유저를 위한 제품입니다. MacBook Pro 라인은 MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17" 및 MacBook Pro 17"Unibody를 포함합니다.
19981 질문 전체 보기
My MacBook Pro turns on but has weird screen.
Hi My MacBook Pro laptop turns on but the screen looks like a bunch of pixels it won't go any further then the start-up screen and then it comes up with a messege that looked like it said that I had to restart my computer. When I do it does the same thing.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 답변
That definitely sounds like a failing video card to me, which is unfortunately integrated onto the logic board.
Just to be sure though, try hooking it up to an external monitor first. If the image on the external monitor is fine, it's not the video card (and the next pieces to try would be the display data cable, then the LCD panel). If the image on the external monitor manifests the same symptoms, you unfortunately need a new logic board.
Good luck!
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hi,
what happened with our problem, did you solve it ?
I think i have the same ...
Thanks
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Here is another user! I had the similar problem. Every time, I tried to re-start 15", but after awhile, the monitor said, you need to restart your computer, hold down the power button until it turns off and then press the power button again. After I read this, i connected the mac to external monitor and try again. It worked. I repeated several times, still works. thanks!
it really helped!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Caroline 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 5,371
