주요 콘텐츠로 건너뛰기
2012년 6월 출시 / Core i7 프로세서 Turbo Boost 포함 / 최대 1 GB DDR5 비디오 RAM
589 질문 전체 보기
Can you replace the HDD with SSD in the 2012 mac pro
I have just bought the 2.6ghz version of the macbook pro with a 750GB HDD and i was wondering if it is possible to replace the HDD with an aftermarket SSD preferably 250GB to 500GB. I know it is possible to remove the superdrive and put in a second SSD but i use the superdrive quite often.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
The title says mac pro but the question is about macbook pro, please note that there is a mac pro unit which is totally different from macbook pro. Please clear up this ambiguity if possible.
댓글 달기
답변 1개
선택된 답변
Yes, it is very easy to install an SSD. Most 2.5" SSD drives will fit and work in your MacBook Pro. You can buy and one of these SSD drives from this link:
http://eshop.macsales.com/shop/SSD/2.5
Some are upgrade kits and others are external dries so make sure you are getting a SSD and not and external drive. This guide will work for your device:
MacBook Pro 15" Unibody Late 2011 하드 드라이브 교체
I do not think that you will need pentalobe screws so you should check the screws on the bottom of your laptop.
Hope this Helps.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Just use the screws from the magnetic HDD you are replacing, because the SSD drive will need to sit inside the MacBooks HDD chassis mount.
댓글 달기
귀하의 답변을 추가하세요
Craig Blake 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 11,270
