주요 콘텐츠로 건너뛰기
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 질문 전체 보기
질문 마감됨
Upper right corner doesn't respond + glue doesn't stick
I just repaired an iPod Touch 4G and everything went great apart from two things:
  • The upper right corner doesn't seem to respond on touches
  • When reassembling, the front panel won't stick together. I used 3M tape, but it doesn't seem strong enough to keep both parts together
Any suggestions/tips?
Thx!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Sounds like the screen you used has a defective digitizer.
When I repair these iPods I usually use a head gun to lightly warm the outer edges of the new glass once it is installed to "melt" the adhesive and then I put the iPod on a flat surface on a microfiber towel and then put a couple of heavy books on top. It always gives it a better stick!
Also, check to see if that top corner is dented or bent. That can always make a difference too
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 544
