주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LT2323p Wide LCD Monitor - Type 3024 - Model 3024HC1
My laptop power on but not display picture
My laptop power on but screen display dark
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 4개
Mere leptope ka screen open ho raha hai but KOi app per click karte man hi wah restart bar bar hone laga lta hai.
Mere leptope ka screen open ho raha hai but koI app per click kate hi leptope bar bar restart hone lag raha hai.
Mera pc on nai ho raha
Power botton on but display not working
댓글 달기
답변 2개
가장 유용한 답변
@asirajimamboleo we need to know what make and model you laptop is. You've selected a Monitor as your device.
First make sure that it is not suffering form a bad backlight. A simple check for that would be to darken the room and turn the laptop on. Then use a flashlight and angle the light at the screen on different areas. See if you can make out your Desktop etc. If yes, then the issue is a failed backlight.
Next, connect an external monitor to your laptop. If that monitor shows properly, you know the issue is with your LCD. Could be the screen, the display cable or even the motherboard connector. If an external monitor does not display an image properly either, the issue could be with your motherboards GPU. Let us know what you find out.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Restart the computer. Ctrl esc, hold down press power button on laptop.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Asiraji Mamboleo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 69
전체 시간: 440
