주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
3019 질문 전체 보기
Why is the battery dropping out every couple of minutes?
I just did a screen replacement for my phone and now it turns on and everything works, including taking a charge; however, every couple of minutes (even when plugged in) the phone shuts off and turns back on. I have the AT&T 32gb version of the iPhone 4s. What could cause this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
선택된 해법
An inconsistent voltage supply would be the culprit of this, the iPhone 4S requires 3.7 Volts minimum I think, anything less and you might as well take out the battery as not enough power is being delivered to run the iPhone.
Cheap battery replacements will cause this, either ask for a replacement one or for a refund and go to another company. Too low a voltage won't cause any permanent damage as it is literally like taking the battery out of a BlackBerry or HTC whilst it is on.
Hope this helps! (Remember, buy cheap, buy twice!)
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Ryan 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 315
