메인 콘텐츠로 스킵하기
6MB 공유 L3 캐시 2.3GHz, 2.6GHz, 또는 2.7GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.7GHz).
456 질문 전체 보기
Can I upgrade flash storage more that 768 Gb?
Hi:
Can I upgrade more than 768gb on a macbook pro retina display? Does it use SSD SATA III 2.5-Inch?
Thanks for the feedback
HUGO
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
4개의 답변
가장 유용한 답변
While this is a "dated" post... I thought I would throw in a quick update and suggestion if anyone with this model comes looking for suggestions. Having had a 768GB SSD 15.4" Macbook Pro Retina (Early 2013), I can relate to the need/want for more than 768GB. I work with larger files quite frequently, and I'm impatient :) Even with SSD use, I find myself sometimes waiting (lol).
There is a new introduction to the market for SSD alternatives for the (2012 to Early 2013) A1398 Macbook Pro Retina (MacBookPro10,1).
Transcend's Jetdrive 720 - 960GB: http://www.transcend-info.com/apple/jetd...
$599+ (As of 6/15/14)
Buying one myself... will post performance reviews on my ifixit profile soon. Stay tuned...
If you like my post, please advance my score (seen above my profile). Thanks all!
J
해당 답변은 도움이 되었습니까?
점수 2
댓글:
JetDrive - They do sell via Amazon (Prime) too (just ordered one in Austria).
의 답변
의견 추가하세요
At this time I'm not aware of any manufacturers that make larger chips. Take a look at the teardown here and you will see that the Retna based MBP no longer uses a user replaceable drive/RAM.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
no, it is flash storage and is not able to be removed from all i heard..... id go with the 15" none retina, it is able to be upgraded at our will and u can remove the cd drive (if you have skills) to chuck in a secondary harddrive.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
To answer your question about form factor, no, the Retina MacBook Pro does not use a standard 2.5" profile. It is a proprietary Apple design that will probably take 3rd parties a while to copy.
This is unrelated to your question, but why do you want/need so much flash storage? The maximum configurable 512 GB should be good for anything you need on the go, and you can always use a 1 TB or larger external HDD at home.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
HugoPeroni 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 4,505
