주요 콘텐츠로 건너뛰기
2012년 6월 출시 / Core i7 프로세서 Turbo Boost 포함 / 최대 1 GB DDR5 비디오 RAM
589 질문 전체 보기
Retina Display Transplant Possible?
Apple has once again dropped the ball on the professional computer users. I'm a photographer that would benefit from the high res image quality of a Retina display, but at the same time I can't give up the flexibility of the traditional form factor. I need to be able to install 2 drives and have have a firewire and ethernet port without adaptors.
Since iFixit are about the only folks that have been inside both versions of the MacBook Pros do you think it's possible to transplant a retina display into the non-retina verson and have the best of both worlds?
The specs suggest that the non retina version is capable of driving the display. What are your thoughts?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
Yes. The same way as always: sell your old unit (complete) and buy a new unit (complete).
It would be cost prohibitive to try to do otherwise.
The entire top case/display is essentially one piece.. the display panel is the "front glass"... the extra 512K VRAM may be needed to run the display and AFAIK you can't swap out video chips on this laptop.
If this Answer is helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
The top end MBP and rMBP video specs are the same GT650M 1GB GDDR5. I'm wondering if the lids may be interchangeable.
Yes I know this is not going to be cost effective for 99% of users but neither are the 3.33GHz 12core upgrade, but those that need it, need it.
I'm hoping that someone that has had the parts personally in hand will speak from experience. Speculation is just that.
댓글 달기
Certain, output to external display.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Brian Jones 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,498
