주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Portable Power Station과 Smart Soldering Iron의 조합인 FixHub Power 시리즈 | Portable Soldering Station의 수리 및 문제해결 정보입니다. 2024년 10월 출시.
FixHub stuck in "Firmware update needed" loop after successful update
I have a FixHub Portable Power Station that is stuck in a firmware update loop. The screen displays "Station Error: Firmware update needed." I have successfully run the update through the FixHub Web Console using a data-capable cable connected to the rear port. The console reports "Update Successful," but as soon as I unplug the device and turn it back on, it displays the same "Firmware update needed" error.
I have already tried:
1. Performing a force shutdown (holding the Action Button for 10 seconds).
2. Attempting to update multiple times via the Web Console.
The error persists every time I power the device back on. Does anyone have any ideas?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 9개
I've forwarded you issue onto the iFixit product team, hang tight!
@issacchandler, thanks for posting. Have you reached out to our support team yet? Given the troubleshooting you've already done. That would be the next best step.
@krisrodriguez Hi, yeah I have. I ended up sending a video of the whole problem. No solution yet though.
@isaacchandler, thanks for the update. When was the last time you had contact with them?
@krisrodriguez, I sent the video on Tuesday morning. It's been a pretty slow process so far. I figure they must be busy, because it takes them a 2-3 days to respond each time.
댓글 4개 더보기
댓글 달기
답변 2개
선택된 해법
@isaacchandler , I spoke with our team and they confirmed that they received the videos. Our product development team is reviewing them now and they should have a solution for you soon.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Okay, I appreciate it. Thank you!
댓글 달기
This usually happens when the update “completes” but doesn’t actually get written into the active firmware partition. So the FixHub Portable Power Station is basically rebooting back into a broken/old slot every time, which is why it keeps asking for the update again.
The key thing here is: the web console saying “successful” only means the upload finished, not that the bootloader switched to the new firmware. If the device fails its post-check, it silently rolls back on reboot, which creates exactly this loop. What normally fixes it is doing a clean recovery-style reflash instead of a standard update. That means keeping it in update mode while reapplying the firmware, and making sure it stays powered the entire time (no interruptions, no unplugging early). If there’s a hidden “factory reset after update” or “erase partitions” option in the recovery console, that’s usually what forces it to stop rolling back. If it still persists after multiple flashes, it’s often a corrupted boot flag rather than the firmware itself, and only a full reset/recovery procedure (sometimes vendor tool or support-level restore) fixes it. At that point it’s less about retrying updates and more about clearing the stuck boot state.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Isaac Chandler 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 50
전체 시간: 204
