주요 콘텐츠로 건너뛰기
Model No. A1367 / 8, 16, 32, or 64 GB capacity
910 질문 전체 보기
질문 마감됨
The display isn't turning on despite being powered?
Question above. The digitizer (that's the black ribbon cable, right?) is intact, but the little chip on a short ribbon appears to be disconnected (I think that's the display cable). If this is the problem, how do I resolve it? If not, what information can I give? Thanks in advance!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
선택된 해법
Yes, that is your display cable. If it is severed, the entire screen assembly will need to be replaced.
Best of Luck,
Tough Gaming Technical Support
Agent Elisha
해당 답변은 도움이 되었습니까?
점수 0
댓글:
It's not severed. It's just the chip at the end of the cable is not connected to the little piece where it's supposed to be connected. In that case, how do I get it back in there?
Can you post a image? That will help greatly.
I see what your problem is. Just align it up and press down. Make sure that is aligned with the chip on the mainboard before pressing down, ad you may break the connector on the mainboard. This connection is required to get the LCD Display Screen to work, it the same as the one undernieth. Best of luck,
의견 추가하세요
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 229
